jansensk's avatar
jansensk
emoji als ssid (updated)
  recently seen a wifi network using an emoji as SSID   been trying to figure out how to do this since just pasting unicode, for example; U+1F30A, just turns out as ?? as network name in my networ...
  • doraemon's avatar
    Feb 26, 2016
    I don't think that the textbox is designed to understand that unicode.
    Hardcoding it will be the solution or use a 3rd party firmware that allows it.
