Ukefc's avatar
Ukefc
Follower
Oct 15, 2017
Enabling VPN for Specific Devices
Hi. I thinking of buying this router. Question about VPN (I have a Private Internet Access account for VPN). Is it possible to set up a VPN on this router so that I can specify which devices use th...
  • JamesGL's avatar
    Oct 18, 2017
    Hi Ukefc,
    The router is VPN passthrough only. It has its own VPN which OpenVPN. For other VPN servers, configuration should be done on the computer or clients.
