pseudo-nym
Sep 16, 2025Aspirant
ERR_SSL_KEY_USAGE_INCOMPATIBLE NETGEAR Nighthawk(R) X4S R7800
Hello, I can't connect to the GUI of my NETGEAR Nighthawk(R) X4S R7800 via several browsers like Opera, Ecosia etc. and get the Error: ERR_SSL_KEY_USAGE_INCOMPATIBLE (Firefox works so far) Th...
pseudo-nym
UPDATE:
I figured out that the latest Firmware right now is V1.0.4.96 but the GUI couldn't download and install it for unknown reason. So I downloaded it manually to install it via GUI.
How ever the issue with the "ERR_SSL_KEY_USAGE_INCOMPATIBLE" still exists.
Please if anyone has an idea for a fix!?
Sep 16, 2025Guru - Experienced User
pseudo-nym wrote:How ever the issue with the "ERR_SSL_KEY_USAGE_INCOMPATIBLE" still exists.
I am a bit confused, since the R7800 manual says the admin interface uses HTTP, not HTTPS. HTTP doesn't use SSL.
I am seeing the VPN icon in your screenshot. Does this issue only happen when you are connecting remotely through the VPN? Or does it also happen locally with no VPN?
