pseudo-nym
Sep 16, 2025Aspirant
ERR_SSL_KEY_USAGE_INCOMPATIBLE NETGEAR Nighthawk(R) X4S R7800
Hello, I can't connect to the GUI of my NETGEAR Nighthawk(R) X4S R7800 via several browsers like Opera, Ecosia etc. and get the Error: ERR_SSL_KEY_USAGE_INCOMPATIBLE (Firefox works so far) Th...
Sep 17, 2025Guru - Experienced User
Might give Voxels FW a try.
The R7800 is EoL so won't be seeing anymore FW updates most likely.
Support and End of Service FAQ | NETGEAR Communities
CrimpOn
Many Netgear routers support both http and https versions of the web management interface. Many modern versions of web browsers have a setting to automatically convert web addresses into https, which can cause this problem. Sometimes deliberately typing "http://" into the address bar will force the browser to use http.
- StephenBSep 18, 2025Guru - Experienced User
Yeah, I know. But I checked the manual before I made that reply.
The manual doesn't say anything about https, and the remote management section specifically says http.
Normal web browser access uses the standard HTTP service port 80. For greater security, enter a
custom port number for the remote web management interface. Choose a number from 1024 to 65535,
but do not use the number of any common service port.The default is 8080, which is a common alternate
for HTTPUsing http for remote management is IMO a bad idea. But the "solution" here might well be to use the VPN and put http:// in the address bar of these browsers.
Or of course try voxel.
