pricerp5
Feb 15, 2017Aspirant
Error log messages in netgear ready share vault
I am receiving the following Windows error log message. Can anyone please tell me what it is referring to?
Nighthawk X8 , AC5300 Triband Router, model R8500, Firmware ver. 10.0.2.86 running on Windows 10.
Activation context generation failed for "c:\program files\netgear\readyshare vault\x86\GenieTimeLineAgent.exe".Error in manifest or policy file "" on line . A component version required by the application conflicts with another component version already active. Conflicting components are:. Component 1: C:\WINDOWS\WinSxS\manifests\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.14393.447_none_42191651c6827bb3.manifest. Component 2: C:\WINDOWS\WinSxS\manifests\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.14393.447_none_89c64d28dafea4b9.manifest.
| C:\WINDOWS\WinSxS\manifests\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.14393.447_none_42191651c6827bb3.manifest |
| C:\WINDOWS\WinSxS\manifests\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.14393.447_none_89c64d28dafea4b9.manifest |
| c:\program files\netgear\readyshare vault\x86\GenieTimeLineAgent.exe |
Thanks in advance! Rick
I uninstalled and reinstalled and have come to the conclusion I did not follow the right set up proceedures when first installing the software. It's back to the manuals for now. I truly appreciate all your help. Thank you!!:smileyhappy:
- pricerp5Aspirant
There is no no noticeable error. I found this error when going through my desktops error log file. It repeatedly occurs approximately every 4 minutes as though my computer was tryiong to connect to ready share or ready share was trying to connect to my computer. I am running a Windows 10, 64bit system on a Lenovo A740 all in one
- ElaineMNETGEAR Employee Retired
Try to uninstall the ReadySHARE Vault software and observe if it will still show the same error.
Then reinstall it.
