frenchcl
Jul 22, 2016Aspirant
Ethernet Cable for Nighhawk R8000 - What to buy
I am far from a techie. I need a longer cable that goes from my computer to my Router. What kind of cable should I buy? Help!!!
- Jul 23, 2016
Nowadays users should buy at least cat6 cables or better cat7 cables!
microchip8
Jul 22, 2016Master
Minimum a Cat5e cable. For future-proofing, get a Cat6 one
- frenchclJul 22, 2016Aspirant
Thank you. I want to get the best as I work from home and need the best speed. So you think this Cat6 is the best? So if I go and ask fro a Cat6 e cable, I should have the correct one.
- microchip8Jul 22, 2016Master
"Best" is hard to find and different people will tell you different things on which brand is best. Cat6 is just a category of cables as is Cat5e. The latter is suited for up to 1 Gbps speeds. Cat6 goes up to 10 Gbps
- aalexandrebetaJul 23, 2016Master
