Kfallsfotoman
Feb 02, 2018Aspirant
Ethernet Cable
Pretty simple question Just got a Nighthawk AC1900 Smart Router - Before purchasing checked a review - One reviewer suggested changing the CAT 5 ethernet cable between the router and cable modem to...
- Feb 07, 2018
Basically, if you are using a 100Mbps rated cable, it might not be the best choice. ISP usually over provision the speeds Up/Down specified. If your service is rated at 100Mbps Down and 100Mbps or less up, you'll lose a little. Cat6 would not lose that little amount. However if you ever upgrade your service Cat5 might not work well.
Here is some info on different cables : https://www.digitaltrends.com/computing/differences-between-ethernet-cables/
Where you would really need the CAT6 if you have a LAN and tranfer files around or execute programs from another PC. Hard wired devices should have CAT6 as the Router itself is 1GB ports. Of course, wired to wireless devices or visa versa would not the the max. speed but will still be faster than if CAT5 were used to the wired devices.
Compared to everything else, upgrading to CAT6 is not usually expensive. It will also improve speed on long runs.
Kfallsfotoman
Feb 03, 2018Aspirant
I guess there are snarky people in all forums - didn't feel these comments were necessary.
I'm simply asking if anyone has tried it -
The basis for the decision is there -
Cat5 has a certain bandwidth - speed - length etc.
Cat 6 has a higher bandwidth - speed etc.
The increased bandwidith of the modem (100mbps) COULD take advantage of the better cable -
In both cases - and all installations - the WAY it is installed has a big bearing (bends- kinks etc) - things pixby dust won't help
antinode
Feb 03, 2018Guru
Yes. Many of us understand that.
> What is it now, Cat5 or Cat5e? [...]
Still wondering.
What, exactly, is your "the modem"? If your your (unspecified) "the
modem" has a gigabit Ethernet port, then either Cat5e or Cat6 should be
adequate (and I'd expect a short run of plain-old Cat5 to work just as
well). If your your (unspecified) "the modem" does not have a gigabit
Ethernet port, then any of this stuff should work as well as anything
else.
> [...] the WAY it is installed has a big bearing (bends- kinks etc)
Define "big". It's all unshielded twisted pairs; higher categories
mostly have more/better twisting. Crosstalk between pairs is generally
more important than disturbances caused the surroundings.
https://en.wikipedia.org/wiki/Category:Ethernet_cables
- KfallsfotomanFeb 03, 2018Aspirant
At the moment it is the standard cable that came with the router - which by the designation on the cable is a Cat 5.
Sorry - forgot to mention
We just bought it yesterday - installed it last night and just finishing configuring all the devices on it - so at the moment I'm just using the cat 5 until I have all devices connected and things settle down -
At the $5-10 cost of a Cat 6 10" cable I'll probbly get one just to see if anything improves - cheap test -
again just was looking to see if anyone had done it
Thanks
- IrvSpFeb 07, 2018Master
