Twint's avatar
Twint
Follower
Nov 27, 2022
Ethernet land line
The light on the router That the Ethernet cable is hooked to is orange Should it be white like the rest of the lights?
  • Orange/Amber means the link runs at 100 Mbps instead of 1 Gbps (white light). If you're sure the link should be at 1 Gbps, try different cables (CAT6 is recommended)
  • FURRYe38's avatar
    Be sure to check the routers user manual for LED activity and indication information.
