Burrisplace's avatar
Burrisplace
Ethernet port doing weird traffic shaping after upgrade from X6 to X10
I just upgraded from a Nighthawk X6 R7900 to a Nighthawk X10 R8900. I wanted to ask the community how to deal with what I believe is an Ethernet port doing weird traffic shaping. Once I upgraded to t...
  • Burrisplace's avatar
    Burrisplace
    May 30, 2018
    Figured this out.  When I opened up the jack and looked into the metal electrical box (gangbox) behind the jack I found that the installer had not carefully made sweeping loops with the excess cat 6 cable. When packing the excess cat 6, they just did a haphazard impetuous violent jam-job creating lots of sharp bends.  Looked like a rats nest!  Sharp bends create impedance and degrade signal.  When I first straightened out the excess and retested speeds, low and behold, speeds jumped from 60/20 to like 200/20. I carefully repacked the excess using long sweeping loops. I then closed up the box with the face plates. It now works fine!
