Buczar
May 20, 2022Tutor
Ethernet ports show activity, but are not allowing connection to the internet
Today when I connected to my docking station, I discovered I could not connect to the internet. First assumption was a Comcast outage which is often solved by the standard turning off of the modem and router, waiting a minute and turning back on.
I discovered that while I could connect to the router's WiFi, I could connect to the internet. I logged into the router via wifi, and indeed confirmed that the only connection method were all by wifi. All of my extenders are connected by ethernet (so can't connect to them via WiFi and get to internet). Laptop at my desk is connected by ethernet (well, MoCA to Ethernet), my gaming console is ethernet. Overall, about 17-ethernet connections throughout my network. None of them are working.
Everything I Google around 'router WiFi working but Ethernet not' tries to trouble shoot the computer connecting. In my case, it seems everything 'can' connect to the router, but it can no longer reach the internet. I'm not sure if something is up with my LAN settings, DHCP, etc. Nothing has changed that I know of since yesterday.
No idea where to go from here to triage. I'm using a Netgear R9000 x10.
What firmware is on the r9000?
what modem/gateway is it connected to?
Are any devices connected directly to the router or are they running through switches/moca adapters?
- BuczarTutor
Thank you for the response!
v1.0.5.40
Arris Surfboard with phone.
All of the above actually. 2 direct runs, one to a moca, one to a switch.
also, whats it showing on the wan port statistics.
Here is the full table:
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time WAN 1000M/Full 7905307 22288261 0 30836 47924 01:00:53:17 SFP+ Link Down 0 0 0 0 0 00:00:00 LAN 1 1000M/Full 2201616 685117 0 5802 1423 01:00:14:52 LAN 2 1000M/Full 01:00:14:52 LAN 3 Link Down 00:00:00 LAN 4 1000M/Full 01:00:14:52 LAN 5 Link Down 00:00:00 LAN 6 100M/Full 01:00:14:52 2.4G WLAN b/g/n 800M 5934127 10571299 0 15000 7657 01:00:14:35 5G WLAN a/n/ac 1733M 22212570 8989667 0 2377 41444 01:00:14:31 WLAN ad Link down 0 0 0 0 0 00:00:00 - plemansGuru - Experienced User
Thats interesting that they're showing connected but no data packets transferring.
Did you try factory resetting and reinstalling?
You could also try reinstalling the firmware then doing the factory reset (or start with that first).IF something is corrupt in firmware, the firmware reinstall covers that. IF something is corrupt in the settings, the reset should cover that.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
