Bsphillips21's avatar
Bsphillips21
Exclamation points-constantly having to reboot!!
Had router for approximately one year. About a month ago internet stop working (exclamation point on phone and home currently unavailable on televisions and tablets).
After rebooting internet works again. Am having to reboot 3/4 times daily now. Reset router, restarted modem and router. Disconnected the router from phone/reconnected. Still having issues. Not very computer savvy. Please help!!
Checked firmware version-v1.0.4.18_10.1.49
Thank you
  • Bsphillips21's avatar
    Bsphillips21
    Aug 14, 2018
    Changed the MTU?? To 1370 and have not had to reboot for 3 days!!! Hopefully that fixed it!!
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    What is the model of the router? did you hook up anything new to the network when the problem started happening? do you notice if the modem reboots or goes offline when you lose connection?
    DarrenM
      Bsphillips21
      Thank you for the reply!
      Model: r8000
      Modem is good, hardwired to laptop and confirmed did not lose signal when exclamation points/ fire tv unavailable occur.
      Did download the nighthawk and genie app on phone. I did fiddle around a little with vpn(enabled then unenabled) and access control with the apps. Just confirmed I do not currently have any devices on pause internet.
      Thank you!
        Bsphillips21
