rey3anthony
Aug 01, 2021Aspirant
Extender say up to 897 mg I have 1000
Hello friends, my internet is 1000 mg the extender says is up to 897 in wifi but in speed test just reach 100m with the extende wifi without the extended 300m I plug the ethernet cable from the extender to laptop still tht same 100m I reset everything and still the same numbers , Im runinng in a 5 band just in case, I reach the end of the road, help
A couple things.
1. the ex6120 only has a 10/100mbps port. its not gigabit. So wired in, you'll max out around that 90-94mbps.
2. extenders cut throughput by 50% for single/dual band extenders. Reason why is they have to use the same chip to go router----extender and then extender-----device. And they can't do both at once. Hence the 50% speeed loss of what speed they're picking up.
3. 2.4ghz is much slower than 5ghz. but 5ghz signal drops off quickly with distance and obsructions.
- rey3anthonyAspirant
so in order to reach my mission ... with this or other extender I can reach the 1000M that I already have?
Not sure exactly what you were saying here
