fastroads
Jun 04, 2016Guide
Extending the network in my house.
Hello, I want to extend our network in the house (5000 sq ft two story) and would like some guideance. I have looked on youtube etc. and found a few videos on extending WPS. So the equipment: R...
- Jun 08, 2016
fastroads wrote:Thanks for the link. It really helped out with settings ext. on both R7000 & R8000. So not to change too many directions here: To extend wireless coverage in the house with the help of the R8000; knowing I do not have a ethernet connection at the location where the R8000 would be sitting and I would like to have the XBox and PS4 connected to the R8000 in some way either wireless or wired. What would be the best setup: AP Mode, Repeater?
AP Mode requires a wired connection back to the router, so repeater is your own choice. You should wire the XBox and PS4 to the R8000 in order to reduce the load on Wi-Fi.
Not sure this is a viable option for me as crawl space is limited between floors.
If I were to run a cat5/6 line to the location of the R8000; this line would have to connect to the main router via a switch or an OnQ panel.
A wired connection back to the router is ideal. If you end up doing this, then switch from repeater mode to AP Mode.
fastroads
Jun 04, 2016Guide
Alrighty then! Nothing is every easy.:smileyfrustrated: I had watched a few videos and this is one - https://www.youtube.com/watch?v=a2wN4wJ2uMw
So extending the WDS is a forgone thing. Flashing the routers to a new firmware doesn't bother me since the R8000 & the R7000 are out of warranty. It certainly can't be harder than reflashing a motherboard from let's say Dell to EVGA.
Where can I find the firmware? I you have any more idea's please post.
Thank's again!
TheEther
Jun 04, 2016Guru
Netgear's implementation of WDS on their routers is very poor. Forgoing it is the correct choice.
I use Asuswrt-Merlin on my R7000. I am very happy with it. You will have to search the forums on dd-wrt.com for the recommended version. Tomato, AdvancedTomato and OpenWRT. You should be able to find R8000 images for some of them.
- fastroadsJun 04, 2016Guide
Thanks so much.
- michaelkenwardJun 05, 2016Guru - Experienced User
Extending a network in a house with many rooms is where Powerline technology comes into its own, especially of there are nooks and crannies beyond the reach of wifi, or thick walls.
I use it to connect my smart BluRay player to the outside world.
- aalexandrebetaJun 05, 2016Master
I'll drill some holes between walls and stories and put eth cables.
Sorry for being old fashioned but always go for the cable!
