fastroads's avatar
Jun 04, 2016
Extending the network in my house.
Hello,   I want to extend our network in the house (5000 sq ft two story)  and would like some guideance. I have looked on youtube etc. and found a few videos on extending WPS. So the equipment: R...
  • TheEther's avatar
    TheEther
    Jun 08, 2016
    fastroads wrote:
    Thanks for the link. It really helped out with settings ext. on both R7000 & R8000. So not to change too many directions here: To extend wireless coverage in the house with the help of the R8000; knowing I do not have a ethernet connection at the location where the R8000 would be sitting and I would like to have the XBox and PS4 connected to the R8000 in some way either wireless or wired. What would be the best setup: AP Mode, Repeater?
    AP Mode requires a wired connection back to the router, so repeater is your own choice.  You should wire the XBox and PS4 to the R8000 in order to reduce the load on Wi-Fi.
    Not sure this is a viable option for me as crawl space is limited between floors.
    If I were to run a cat5/6 line to the location of the R8000; this line would have to connect to the main router via a switch or an OnQ panel.
    A wired connection back to the router is ideal.  If you end up doing this, then switch from repeater mode to AP Mode.
