Ant30
Nov 16, 2021Aspirant
Extending Wifi into external garage - help?
Hello all. Wondering if someone can help. I have a R800P in my property which in the house has amazing signal strength. We’ve just had our external garage converted (around 5m from the house) and w...
Nov 16, 2021Guru - Experienced User
Any chance of getting a CAT6A lan cable from the house to the garage? This would be preferred. Then you can have a hard wired connection to the garage, then place a 5 port Gb LAN switch in the garage and then connect a wireless AP like a EX7700 in AP mode in the garage that connects wired to the house that would provide wifi coverage in the garage area.
- Ant30Nov 16, 2021AspirantThanks for your suggestion buddy. I have thought about this but would mean either digging up the garden (my garden is higher level than the garage) or going out of the roof down drainpipes digging up the perimeter etc. The garage is on the same electricity supply, are those plugs you can get any good?
- KitsapNov 16, 2021Master
The proper term is powerline ethernet adapter. Search for that on Amazon and you will get plenty of results with ratings and answered questions.
Some are ethernet in and ethernet out, others are ethernet in with ethernet plus wi-fi out. Many applications are very successful. Occasionally they don't succeed for the situation where they are applied. Your application seems ideal.
- FURRYe38Nov 17, 2021Guru - Experienced User
If the garage is on the same power circuit, the power line adapters would be another suggestion and would work.
Ant30 wrote:
Thanks for your suggestion buddy. I have thought about this but would mean either digging up the garden (my garden is higher level than the garage) or going out of the roof down drainpipes digging up the perimeter etc. The garage is on the same electricity supply, are those plugs you can get any good?- Ant30Nov 17, 2021AspirantThanks all. Bought some power line adapters, got home and realised the netgear nighthawk extender I have doesn’t have a Ethernet input! Can someone recommend a decent wifi extender to plug into the power line adapter ?
