Ant30
Nov 16, 2021Aspirant
Extending Wifi into external garage - help?
Hello all. Wondering if someone can help. I have a R800P in my property which in the house has amazing signal strength. We’ve just had our external garage converted (around 5m from the house) and w...
Ant30
Thanks for your suggestion buddy. I have thought about this but would mean either digging up the garden (my garden is higher level than the garage) or going out of the roof down drainpipes digging up the perimeter etc. The garage is on the same electricity supply, are those plugs you can get any good?
Kitsap
Nov 16, 2021Master
The proper term is powerline ethernet adapter. Search for that on Amazon and you will get plenty of results with ratings and answered questions.
Some are ethernet in and ethernet out, others are ethernet in with ethernet plus wi-fi out. Many applications are very successful. Occasionally they don't succeed for the situation where they are applied. Your application seems ideal.
