OnesQuared's avatar
Oct 29, 2017
Extensively High ping on wow with R7000
My brother recently purchased the R7000 model and after the switch, my WoW ping has been unnatrually high, fluctuating from 12k to 22k.
The firmware was updated earlier today as of ( oct 29/2017)
My pc is on Windows 10, windows firewall has exception for all blizzard products, such as the battle.net app, wow and etc etc.
I run bit defender as anti virus.
I've tried port forwarding with no avail and honestly at a loss on what could solve the issue ,any advice would be appreciated.
  • I solved the issue, atleast for WoW, you just turn off ipv6 from the system-> network
      • William10a's avatar
        William10a
        Master
        What was your like before the new netgear was install was it a standard modem to router to computer network?
        Did the new netgear replace another router or did you just added the netgear after the your old router?
  • Has anyone had any luck fixing this issue? I feel that this could be the QoS feature wrecking havoc for us....
    • OnesQuared's avatar
      OnesQuared
      Guide
      • Macbo101's avatar
        Macbo101
        You mean in thew PC itself?
        Sorry I didnt get it ::P
