Stuart_C's avatar
Stuart_C
External antenna power rating
Hello all,
What RF power rating is the MR1100 rated at.
I am wanting too use a external antenna rated at 10watts.
Is this OK or will it damage the Router or antenna.
Regards
Stu
  • michaelkenward's avatar
    michaelkenward
    As the label says, the MR1100 is a Mobile Router. You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Mobile Routers, Hotspots & Modems
    Those things are very different from the standard Netgear Nighthawk routers covered in this section. I doubt if many people familiar with the MR1100 hang around here.
    I will ask the Netgear moderator to move your message.
