JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
HWAM
Dec 18, 2017Apprentice
JamesGL wrote:Hi All,
Can you tell me why they do not use the release page to list the changes? For us it's very important what's changed. And it not wrong to admit faults. Just be honest to all Netgear users. The number of posts were less if Netgear was quicker with reporting the issues on the community. Let us know what the developer team is doing.
chopin70
Dec 19, 2017Virtuoso
Connection is better clearly after hard reset: speedtest.net doesn't kill it. But randomly, wifi connection fails. Turn on/off wifi button on router fixes it. Also switching to 5 Ghz and back to 2.4Ghz fixes it or vice versa if the 5GHz fails
Did theses update fix WPA2 in AP mode ?
- HWAMDec 19, 2017Apprentice
I had to update to 1.0.9.18 an hour ago because also my old firmware version got the same problem again after 36 hours. I thought I had fixed it with an old V1.0.9.6_1.2.19 after flashing via the first FW ever. 3 resets and 3 old FW versions were not enough to make it it stable again.
I do not have the trust 1.0.9.18 is solving the 2.4GHz problem. I guess I have to buy a new router. Downtime is not acceptable anymore.
- mzguyDec 19, 2017Apprentice
HWAM wrote:I had to update to 1.0.9.18 an hour ago because also my old firmware version got the same problem again after 36 hours. I thought I had fixed it with an old V1.0.9.6_1.2.19 after flashing via the first FW ever. 3 resets and 3 old FW versions were not enough to make it it stable again.
An earlier firmware seems to have fixed it though. More than a week is pretty good:
Can someone please point me to the downgrade process, so I can downgrade to 1.0.7.10_1.2.3? I don't have any confidence Netgear will fix this in the next 3 weeks.
