JamesGL
Dec 18, 2017NETGEAR Employee Retired
Feedback for R7000 New firmware 1.0.9.18
Hi All,
Please post here for any update/issue related to the latest firmware 1.0.9.18.
- Mar 07, 2018
You should review this and maybe revert back to this recommended version of FW:
Alfikwrote:I've looked here again after a while and I can't belive the problem is still not solved....
Since I've flashed Tomato a few weeks ago I've forgotten that I have a router- it's working perfectly getting dust because i do not touch it at all :-)...
Parental control works perfectly, 0 drops, strong signal - save your time and do a similar thing!
chopin70
Dec 19, 2017Virtuoso
Connection is better clearly after hard reset: speedtest.net doesn't kill it. But randomly, wifi connection fails. Turn on/off wifi button on router fixes it. Also switching to 5 Ghz and back to 2.4Ghz fixes it or vice versa if the 5GHz fails
Did theses update fix WPA2 in AP mode ?
HWAM
Dec 19, 2017Apprentice
I had to update to 1.0.9.18 an hour ago because also my old firmware version got the same problem again after 36 hours. I thought I had fixed it with an old V1.0.9.6_1.2.19 after flashing via the first FW ever. 3 resets and 3 old FW versions were not enough to make it it stable again.
I do not have the trust 1.0.9.18 is solving the 2.4GHz problem. I guess I have to buy a new router. Downtime is not acceptable anymore.
- mzguyDec 19, 2017Apprentice
HWAM wrote:I had to update to 1.0.9.18 an hour ago because also my old firmware version got the same problem again after 36 hours. I thought I had fixed it with an old V1.0.9.6_1.2.19 after flashing via the first FW ever. 3 resets and 3 old FW versions were not enough to make it it stable again.
An earlier firmware seems to have fixed it though. More than a week is pretty good:
Can someone please point me to the downgrade process, so I can downgrade to 1.0.7.10_1.2.3? I don't have any confidence Netgear will fix this in the next 3 weeks.
