Rangersmjs's avatar
Rangersmjs
Fios and X6S
Hey Folks - trying to get some help to see what’s possible. I have fios TV and gigabit internet. The speed and range is rough some times, so trying to improve it. I have about 30 devices connected bc of a lot of smart items in my home.
I am not great with internet tech so please bare with me. I am looking at the R8000P bc of the range and the number of devices it supports. But, after reading a bunch of different forums, not sure how to go about doing that with fios router. Have read about bridging and a few other options but not totally understanding. Also seeing issues where it could effect my TV.
I have the fios Gateway G1100. I have it connected via coax so think I still need to keep it connected so my boxes (also on coax) can get the signal as well as the one that is on wifi.
But, can I get this router and somehow use it in conjunction with my fios router/modem to get better connectivity and range?
Thanks in advance!
  • FURRYe38's avatar
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
    3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
    https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
    • Rangersmjs's avatar
      Rangersmjs
      So, you don’t recommend a double NAT? Is there another, better option or does Fios just suck and not play well with others lol.
      Or, as long as Verizon can help set their router into bridge mode, I am good? Will someone at Verizon actually be able to help me?
      • FURRYe38's avatar
        Yes double NAT is NOT recommended. If the ISP modem can be bridged fully, then this should work. Ensure the ISP can help you with this and setting up any user account information that maybe needed on the NG router. The ISP will have all this information...
        If the modem can't be bridged, then try option #2 of the suggestion list.
