HiRenee
Jan 20, 2019Follower
FIOS Quantum Gateway + Orbi + Nighthawk R9000
I'm thinking about getting the FlashRouter Nighthawk R9000 to use as a dedicated VPN router. I currently have an Orbi (router & satellite) connected to a Fios Quantum Gateway. Can I use the Nightha...
- Jan 23, 2019
yes you can use the nighthawk with orbi its suggested to set it to AP mode or connect the orbi to the nighthawk and then put the orbi in ap mode.
DarrenM
DarrenM
Jan 23, 2019Sr. NETGEAR Moderator
DarrenM
