tdunham
Feb 14, 2020Tutor
Firmware Check Error
I am using the app, and unable to update my firmware. Bought the router new 6 mos ago, and haven't been able to run an update, so I'm still on 1.02.46. Any advice on how to get the update functioning? I get a "firmware check error" each time.
Updates are always recommended over a wired connection using the WebGUI at http://192.168.1.1 - do not use crappy apps and certainnly no wifi either. Firmware updates are delicate processes. The tiniest interruption and you end up with a bricked router
- tdunhamTutor
Apologies. Found the manual, followed the instructions. updated via web. no idea why the app won't work, but atleast im updated now!
- labattMentor
Just FYI. The app update process is a good way to soft brick the router. Then have to go through the pain of a tftp process so do not do it.
Best way, is read the user manual and do a manual update which is connect a PC/MAC to the router via Ethernet connection.
- microchip8Master
