evanstome's avatar
evanstome
Initiate
Oct 06, 2021
Firmware corrupt - AC1900
Hi. I triggered a firmware update to the router (which is actually R6800 AC1900) which seems to have failed.
Symptoms - solid amber light on power indicator.  When reset (turn off, hold reset while powering on) the power light blinks white.  No wifi presented, no ethernet connection.
I've done plenty of reading about the tftp update, and I'm fine with performing that, but I cannot ping the router to establish a connection to push the firmware! I am connected via ethernet cable from my macbook to LAN port 1.
I have manually set the mac ip address to 192.168.1.X (where X is not 1) and subnet mask to 255.255.255.0. Pinging 192.168.1.1 returns timeout.
I've also tried 192.168.0.X.  Pinging 192.168.0.1 returns timeout.
I've tried this when it's in the solid amber light state, as well as the blinking white state.
At a loss.... any suggestions of other ways I can at least get the connection so I can try tftp?  I've tried to be as comprehensive as I can in my description - thanks in advance!
