BabyDar's avatar
BabyDar
Firmware Update Failure Nighthawk AC1900 R6900
I have been unable to update the firmware today.  Signing in to the network going to ADVANCED > ADMINISTRATION > ROUTER UPDATE it says I'm currently at 1.0.1.26 and should be at 1.0.2.16_10.  I click the download button and it says ROUTER DOWNLOADING but quickly follows with FAILED TO UPDATE FIRMWARE.  Any help would be appreciated.  I'm not having any particular problems other than slower than molasses internet speed that probably is the fault of my ISP.  Maybe I should let well enough alone.
    • BabyDar's avatar
      BabyDar
      Thanks for your reply DarrenM.  This is EXACTLY how I attempted to update the firmware, ethernet connection and all.  It wouldn't work for me.
      • michaelkenward's avatar
        michaelkenward
        You are trying to jump near on 10 firmware versions. That's three years' worth.
        It might help to try an intermediate version or two. Sometimes Netgear puts out "severe" upgrades that change things so much that you need to retrace your steps.
  • Thank you, that does make sense.  I will go at it from that angle.
      michaelkenward
      Good luck.
      There are also times when Netgear advises a reset and/or reboot before the upgrade.
      • BabyDar's avatar
        BabyDar
        Do you mean that little hole on the back of the router?  Would that reset my password?
