WhoDatSaint's avatar
Apr 08, 2021
Firmware Update for R6400
Trying to update the firmware on the router. I’ve tried via the app and trough router login.net. I get Unable to download GUI language file from Netgear server. I’ve tried downloading the firmware from the website and unzip the file there’s nothing there. Anyone have any recommendations
  • plemans's avatar
    You have the R6400? What version of it?
    What device are you using to extract the file?
    What web browser are you using?
    I just tried on v1 and v2 off the firmware for it and was able to download/extract them both.
    • WhoDatSaint's avatar
      WhoDatSaint
      Tutor
      V1,
      Windows 10
      Tried using internet explorer, Firefox, chrome, and edge browsers
      Using a free file unzip program. Think it’s called unzipper. Can you recommend a better one.
      Anything would be greatly appreciated
      • antinode's avatar
        antinode
        Guru
        > Model: R6400|AC1750 Smart WiFi Router
           Is that accurate?  R6400[v1] or R6400v2?  Look for "Model" on the
        product label.  Current firmware version?
        > [...] I get Unable to download GUI language file from Netgear server.
           "get" _how_?  When you do _what_, exactly?
        > [...] I've tried downloading the firmware from the website [...]
           Which file, exactly, did you download?
        > [...] and unzip the file there's nothing there.
           You determined this _how_, exactly?  "nothing", or not what you
        expected, or what, exactly?  An empty firmware kit is extremely
        unlikely.
        > [...] Anyone have any recommendations
           Sure.  Provide enough actual information that a reader who can't see
        what you have, or what you did, or what happened when you did it, might
        be able to understand all those things?
           Possibly relevant:
              https://community.netgear.com/t5/x/x/m-p/2060035
        > Tried using [...]
           Really shouldn't matter much.  What you actually did with any
        browser, and what happened when you did it, would be interesting.
           "Tried" is not a useful problem description.  It does not say what
        you did.  It does not say what happened when you did it.  As usual,
        showing actual actions (commands) with their actual results (error
        messages, LED indicators, ...) can be more helpful than vague
        descriptions or interpretations.
        > Using a free file unzip program. [...]
           Again, practically any unzip program should be able to extract the
        files from a Netgear router firmware kit.  Including the File Explorer's
        built-in "Extract all..." feature.
           As for "Using", see "not a useful problem description [...]", above.
  • I’ve been able to complete the firmware update. The extractor finally worked.
