occicat's avatar
Feb 21, 2021
Firmware update V1.0.4.84_10.0.58 r6700v3
Ok I’m on a smartphone right now and it’s cause I did a firmware update that was supposed to take 2 minutes but has gone on for 30 and now I can’t connect to the router and have no wi-if.
I’m afraid if I power cycle the router it will be bricked completely.
It’s not able to be connected to at all now.
How can a firmware update done through the panel directly to Netgear cause this issue?
  • I’ll also say that the power light is now blinking and there was no power interruption during the update or loss of internet connectivity.
  • plemans's avatar
    I'd highly recommend against every updating via a phone, the app, or over wifi.
    when we see corrupt firmware issues, this tends to be the cause. I always recommend doing it over a hardwired connection.
    ou can try recoving it with tftp or nmrpflash.
    are you on windows? if so, follow this guide
    https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
    just make sure you enable tftp
    https://www.thewindowsclub.com/enable-tftp-windows-10
    and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
    https://www.youtube.com/watch?v=R9DLrLQrpaw
    and if that doesn't work, you can try using nmrpflash
    https://github.com/jclehner/nmrpflash
    • occicat's avatar
      occicat
      Star
      The thing is I did the upgrade via the admin panel via the browser. So your saying the computer your using that’s connected to the router handles the firmware update and not the router itself?
      I’d have thought after it was downloaded to the router and you click go it’s all handled by the router and not the other way around?
      • michaelkenward's avatar
        michaelkenward
        No.
        If you initiate the update through the router or with an app, the router goes to the Netgear server and gets the new firmware file, stores that in memory ands then writes the firmware into memory.
        If you update manually, using a file you retrieved from the support section, you have a direct connection from your desktop and can write your new file into the router's memory.
        You can see that the first automated option can fail if there is an interruption in the original process of retrieving the firmware.
