Markg2
May 05, 2016Tutor
Firmware updates--check, do, when...?
R7300DST
Do you need to know your current version and then check periodically or is there some way to be automatically notified of an update to your date and model router?
How do you know when it's best just to leave well enough alone or there's really some important (to most users) change in the firmware?
Mark
- Retired_MemberMay 05, 2016
When you log into the router it will show you when a update is available. If all is working fine then leave it be. Unless you have time and are knowledgeable enough to undo the update.
Many recent updates from NG add some option and end up breaking several others.
- Retired_Member
- Markg2Tutor
Thanks, the answer suits me just fine.
- VE6CGXMaster
By FCC rule firmware change process is changing. Most important thing is it won't let
you go back down to older firmware soon. Think twice B4 updating firmware then.
- Retired_Member
Sounds like nitgear would finally have to ___t or get off the pot to stay in business.
