eson's avatar
eson
Firmware upgrade to V1.0.7.6 breaks wifi security settings
WiFi password settings are gone after firmware upgrade to V1.0.7.6. Factory reset did not help. No password setting and can't change channel setting. I also tried reflashing firmware.
  • Welcome to the community, eson
    Thank you for bringing this to our attention. I will go ahead and forward this to our engineering department.
  • It's working when changed to English user interface. So this BUG seem to affect only localised user interface. At least, it affects Swedish interface.
    • ElaineM's avatar
      ElaineM
      NETGEAR Employee Retired
      I just want to let you know that this will be fixed in the next firmware release.
    • ElaineM's avatar
      ElaineM
