helix20017's avatar
helix20017
Firmware V1.2.1.6_1.1.86 Connection Drop Out
Hi,   Since updating the R8000P to the latest firemware (V1.2.1.6_1.1.86), the router will not connect to the internet, unless it is rebooted. Despite this inability to connect, it says 'internet s...
  • michaelkenward's avatar
    michaelkenward
    Dec 17, 2017
    antinode wrote:
    Did you try
    resetting (and reconfiguring) the router after loading new firmware?
    This is probably the best advice to try first.
    There is a manual for the R8000P somewhere at the end of this link:
    >>>> R8000P | Product | Support | NETGEAR <<<<
    See Reset button on page 12.
    Remember, when you have a modem and router in the system you have to do things in the right order.
    • Turn off and unplug the modem.
    • Turn off the modem router and computers.
    • Plug in the modem and turn it on. Wait 2 minutes.
    • Turn on the modem router and wait 2 minutes.
    • Turn on the computers.
