BellamyDustin's avatar
Feb 03, 2023
flashed DD-WRT onto my R7000 router.
Hi guys, I'm new here and to DD-WRT. Recently, I flashed DD-WRT onto my R7000 router. I selected the 'dd-wrt.K3_R7000.chk' file on that list.
All was working fine until this morning when my power went out for about 5 seconds. Of course my router is plugged in and of course lost power also. I expected it to boot back up and work as normal but that was not the case.
It boots up, cycles through lights but then the power light stays amber and it doesn't broadcast any WiFi connections (which I wouldn't expect since it isn't showing full on power.) It also semi lights up the 2.4 indicator. When I plug my laptop directly into the router via an Ethernet connection, I do get a legit IP address but no actual connection. The router lights up amber on the Ethernet port I am connected into also. After a while, my IP address is dropped in place of a self assigned one.
  • FURRYe38's avatar
    You'll need to post over on the DD-WRT forums for there help and information regarding there FW. This forum is for NGs stock loaded routers.
    Good Luck.
    • BellamyDustin's avatar
      BellamyDustin
      Tutor
      Good Luck.
      Much Thanks
  • michaelkenward's avatar
    michaelkenward
    BellamyDustin wrote:
    It boots up, cycles through lights but then the power light stays amber ....
    On stock firmware that is a sign that your router has corrupt firmware.
    I hope that the people behind DD-WRT firmware have "get me out of here" instructions – perhaps you checked them before you went down that road – but as FURRYe38 says there's nothing that anyone from Netgear can do to help you with third-party firmware.
      BellamyDustin
      Tutor
      Sure thank you sir
