rakiboy
Feb 14, 2017Follower
FTP and VPN acces
Hi There I need a help to set up a vpn acces and FTP server. I have R7000 router connected to internet and behind him there is a Qnap NAS server. I have enabled the option in qnap to have a ftp...
- Feb 20, 2017
Also, on FTP you need to make sure the QNAP is configured to use passive FTP with a small port range (perhaps 4 ports for connection), and you will need to forward those ports to the QNAP as well as the control port.
Most FTP clients will require masquerading to be set on the QNAP in order to connect over the internet. FileZilla is one that doesn't need that.
JamesGL
Feb 19, 2017NETGEAR Employee Retired
Hi rakiboy,
1. What VPN server you are using?
2. Did you open the ports of the FTP server and the VPN server on the router via port forwarding?
3. What is the firmware version of the router?
- StephenBFeb 20, 2017Guru - Experienced User
- JamesGLFeb 28, 2017NETGEAR Employee Retired
Hi rakiboy,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
