wyogal's avatar
wyogal
Get message ENETO: looking up IP address from DHCP
I am just changeing my old Netgear for a new onr.  Everthing on my personal side works great now.  I also had my work computer hooked up to it and it worked fine before I switched it out.  Now when I try to log in on the work computer it says ENETO: lOOKING UP IP ADDRESS FROM DHCP AND WON'T LET ME LOG IN.  Help-everthing worked fine before I switchd it out and all the plugs are in the same place.
  • > I am just changeing my old Netgear for a new onr. [...]
       Thanks for the detailed descriptions of both those devices.
    > [...] Now when I try to log in on the work computer it says ENETO:
    > lOOKING UP IP ADDRESS FROM DHCP AND WON'T LET ME LOG IN. [...]
       "it"?  With my weak psychic powers, I have approximately no idea what
    "log in on the work computer" actually means.  A quick Web search for a
    spelling-corrected version of your error message ("ENET0", not "ENETO")
    suggests that you might be using some kind of VPN, about which I know
    nothing.  Someone at "work" might know for whose IP address it's
    looking, and why it doesn't find it.
    > [...] Everthing on my personal side works great now. [...]
       Which suggests that, whatever the problem is, your (unspecified) "a
    new onr" might not be the culprit.
    • wyogal's avatar
      wyogal
      Sorry, I am not very literate on computer info & I am very general.  "It"  is my Working from home computer.  I have another computer-- personal hooked up also and it working fine.  The item that is new is the Netgear.
      Thank you for trying to help me.
  • michaelkenward's avatar
    michaelkenward
    What Netgear device are we talking about here?
    Connected how? Wifi? Wired Ethernet?
    Windows PC?
    Where do you see that message?
