StephLader's avatar
StephLader
GS105v5 causes pixelated areas on PVR
Hello there,
I purchased this device about 3 months ago and everything seemed to operate just great. In the last 10 days the device has been causing errors in the video stream.
The router is located in the basement and sends signal from LAN 3 from the router to the main wall socket upstairs. From that socket I run a CAT 5 into Port 1 on the NETGEAR GS105v5. From port 2 I runt a CAT 5 to the Optic TV Box(PVR) while ports 3,4&5 go to 3 desktops via CAT 5 cables.
On random basis the video feed going to the PVR ( as live programming) is pixelated.
It worked with no problems for 3 months but now without changing anything in the setup it simply errors this way.
Any help would be greatly appreciated.
Thank you.
  • Are you sure it's the switch? Try to rule out the router first, then if it's the switch I'm afraid yoou may need to replace it
    • StephLader's avatar
      StephLader
      Thank you for the help on this one! I had the internet provider replace my router yesterday with a new one and the problem persists with the same symptoms. Yes, I can confirm that if I take the switch out of the context the PVR runs without problems.
      • microchip8's avatar
        microchip8
        Master
        Then your switch is faulty. If it's still under warrenty, you may contact NETGEAR for an exchange. If they do difficult about it, might buy a new switch instead
