Greyman65's avatar
Greyman65
Follower
Jun 25, 2021
GS116 direct replacement
Which model will Directly replace my GS116UKv2?
Is the GS116E the same?
1 Reply
  • plemans's avatar
    The GS116 is just an unmanaged 16 port switch.
    the GS116e is a ProSafe plus version that has additional configuration options.
    If you're just looking for an unmanged switch, there's plenty of 16 port versions out there.
