riccardop's avatar
riccardop
Hardware issue (reset not working)
The R8000 - Router WiFi Gigabit Tri-Band AC3200 Nighthawk X6 stopped prividing wi-fi.
Even if enabled on the dashboard, the wi-fi network is not present.
Tried to hard reset it.
The router just show AC light and does not reset.
No login is more possible
  • FURRYe38's avatar
    Try a different power adapter.
    If that fails, router may need replacing.
    • riccardop's avatar
      riccardop
      Thank you.
      Seems an hardware issue, but it appears that Netgear does not provide hardware support for this model anymore, even if it's still under hardware warranty. Can you confirm?
