Crazyhuntaholic
Jul 30, 2022Aspirant
Has anyone figured out how to fix a bricked router out of the box
Bought a nighthawk router years ago before I was going to move. Moved a couple months later took it out the box instant orange light. Tried fixing it nothing worked and I was past best buys return wi...
Crazyhuntaholic
its a r7000p the most expensive one at its time. confused when you "then it send to PUT the command." Other then this cause I do not know what you mean I have done everything but its just always fails to connect to the router when i start a tftp in cmd or any third party program. I do get "Warning - Multiple default gateways are intended to provide redundancy to a single network (such as an intranet or the Internet). They will not function properly when the gateways are on two separate, disjoint networks (such as one on your intranet and one on the Internet). Do you want to save this?" I have no idea if this messes with it or not? It does not fail instantly it at least tries for a minute before it says fail so i know it sees it and tries. and Yes my computer is only hooked up to this router and nothing else.
michaelkenward
Jul 31, 2022Guru - Experienced User
- wcalifasAug 06, 2022Prodigy
amber light usually means bad power adapter, try a different power adapter. You can also try to ping it and see if you get a response. Or its firmware could have somehow gotten corrupted and you can try to reload it with the tftp method.
