socalspartan
Mar 29, 2017Aspirant
Has anyone got the link agregation to work on their R9000 and Nighthawk switch?
I did the step by step procedure on this link but still wont work. Has anyone go the link agregation to work on their R9000 and Nighthawk switch? https://kb.netgear.com/000037841/How-do-I-set-up...
- May 01, 2017
For the GS808E management, you can use a different single GbE connection - just do _not_ use the two aggregation ports on the R9000 (#1 and #2) and leave the two ports you intend to configure to a static LAG open. Unfortunately, Netgear has added to much UI "intelligence" requiring either both ports down, or both ports up on a GbE link.
We're using the second LAG available for configuration on the GS808E to connect a NAS in a static trunk with Blanced-XOR mode, too.
As Xavier already mentioned, you need at least the R9000 1.0.2.18 Beta (which does come with QoS) or the 1.0.2.30 released these days to enable the static LAG on the R9000 port #1 & #2:
Mar 29, 2017Guru - Experienced User
Might follow these guys here:
- XavierLLMay 01, 2017NETGEAR Employee Retired
Hi socalspartan
Sorry for the delay, could you check that you are using the latest R9000 firmware (1.0.2.30) as it's the one that we added Static LAG ( required to set up the lag on the GS808E)
https://www.netgear.com/support/product/R9000.aspx#Firmware Version 1.0.2.30
Moreover if you are already using the 1.0.2.30 please double check that the LAG is configured as a Static LAG otherwise the LAG will not work.
Hope it helps
Xavier Lleixa
NETGEAR CBU PLM
- schumakuMay 01, 2017Guru - Experienced User
