SHD
Jul 10, 2021Initiate
Have to restart router every 15 mins
I have a R6800 router which fails every 10-15 mins. No internet connection. Works again after restart, then stops again after 10-15 min. Anyone who knows why?
- Hi. Tried reseting the router and updated the firmware to V1.2.0.76 1.0.1 This seems to have solved the problem. The router has not been in use since 2019, so I guess it needed firmware update. Thank you.
What firmware version are you on?
What modem/gateway is it connected to?
When it fails, what does it say? "connected, no internet" do devices disconnect from the wifi, does the wifi stop broadcasting? what actually happens?
