JenKat13's avatar
JenKat13
Follower
Aug 06, 2017
Help! Nighthawk installation
I have had a ton of issues setting up anything with my internet. This was supposed to make things easier. I bought this Router, because with Fiber Optics, I was told I did not need a Modem. Low and b...
  • JamesGL's avatar
    Aug 09, 2017
    Hi JenKat13,
    You can follow the user manual of the router.
    1. How is the router connected?
    2. What are the devices connected to the router? wired?
    3. What are the lights on the front panel of the router?
