Kuroodo
Aug 19, 2018Tutor
Help Stuck In Bridge Mode
My modem lost internet so wanted to connect router to mobile hotspot until it got fixed. I didn't enter the hotspot password when enabling bridgemode and now my router is stuck. I can't access the ...
- Aug 19, 2018After resetting my router and restarting my PC for the 80th time, it started working again.
Nothing to see here I guess...
antinode
Aug 19, 2018Guru
> [...] I've pressed the reset button for 10 seconds and even 30
> seconds. Can't get it to work. [...]
What, exactly, happens when you try that? Do the LED indicators
indicate anything interesting?
You might also try doing the reset (and ten seconds should be long
enough -- watch the LED indicators) with nothing connected to the router
(except its power adapter).
