Kuroodo
Aug 19, 2018Tutor
Help Stuck In Bridge Mode
My modem lost internet so wanted to connect router to mobile hotspot until it got fixed. I didn't enter the hotspot password when enabling bridgemode and now my router is stuck. I can't access the ...
- Aug 19, 2018After resetting my router and restarting my PC for the 80th time, it started working again.
Nothing to see here I guess...
Kuroodo
Aug 19, 2018Tutor
Well when holding down the button, the power led starts blinking orange. When letting go, my router starts doing some light display for a few seconds and then everything goes off and power led goes orange. Then some of the lights come back on slowly
michaelkenward
Aug 20, 2018Guru - Experienced User
It is slowly rebooting itself and running through various checks before it establishes a connection with whatever modem sits in front of it.
Remember, when playing around with a mix of devices you need to reboot the network in the right order.
- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
