Katkota
Nov 25, 2017Guide
Help with optimal settings on Nighthawk R7800
Hello folks; I just received my new R7800 Nighthawk X4S router and i configured it and set it up & i updated the firmware to 1.0.2.38 which is the latest and it works but i noticed the speed im gett...
- Nov 27, 2017
Its because its not Netgears original firmware, although its built on it. Voxels firmware always shows this, I guess there is some check in offical firmware to say its the latest so you can use the built in update feature for new offical firmware, but its fine and you can ignore that message and update to Voxels.
Katkota
Nov 26, 2017Guide
Thanks for your advice and for the link. Currently i'm on v1.0.2.36 and when i tried to upgrade to Voxel version 1.0.2.41SF, i got a message saying this Voxel version is older than the version i currently have although i see on Voxel website the date of that version to be 11/2017. Any idea why is that?
Killhippie
Nov 27, 2017Prodigy
- KatkotaNov 27, 2017Guide
I did install it and so far so good. Thanks a lot for all the help :-)
