arie52
Oct 10, 2022Aspirant
Hi everyone
I have a problem . I put my Nighthwak R 7000 IN THE BRIDGE MODUS AND MY ROUTER WAS ALSO IN THE BRIGDE MODUS.
NOW IT DOES NOT WORK ANYMORE. HOW CAN I GET THE NIGHTHAWK OUT OF THE BRIDGE MODUS?
I TRIED AT 192.168.1.1 BUT I CANNOT APPROACH THE ROUTER
BEST REGARDS
ARIE
Factory reset it. Push and hold reset for 7-15 seconds while powered on.
Thats probably the fastest/easiest way
- arie52Aspirant
i will try again but did reset the router
and what happens when you try to connect to it?
Is it disconnected from the other routers/modems?
Have you checked to see what ip address its assigned to itself? The default is 192.168.1.1 but some will auto switch to the 10.0.0.1
