JohnnyR2D2
Jul 16, 2017Guide
Home Network Setup Advice Please
Hello, Because I keep upgrading my routers I have now three Netgear routers in different places of my home (WNDR4500, R6300 and an R8000). Since I work from home and need redundancy, besides the ...
- Jul 16, 2017
AP mode on the routers is a quick and dirty way to enable.... AP mode - turns off pretty well all the features and makes tem layer 2 devices.. But, since you went through the excersise already, and disabled what needed to be disabled, you should be good to go. Except you probably do not have NTP working on the NG routers, as you would use the WAN port on the routers, if you used the AP mode selection on the routers, which is buggy with some of the NG routers, so, you would end up using a LAN port, worst case, anyway.
There is no way to disable NAT on these routers.. If you are using different SSID's, that is probably the way to go, as I don't think any of these routers have an min RSSI setting, and there is no proprietary means to kick wireless client off of AP's that are sticking. They don't support 802.11.r/k/v, and alot of wireless clients don't work well with 802.1/r anyway. I'm not sure if they have a wirless TX feature to tweak your TX ouput, whihch is key when trying to set up a wireless environment, to get wireless clients to correctly roam. If you want to check the manuals to your routers, go here.
EDIT: Don't use auto channels ever. These routers are smart enough to pick the correct channel. They usually end up pick an overlapping 2.4ghz channels. Use 1,6,1 for 2.4ghz. You can call SSID anything you rwant. But, adding the _ext on the outdoor APisn't doing anything, as extenders do that for different reasons.
EDIT2: If you want to get real experimental with your AP's (using one SSID for 5ghz and one SSID for 2.4gz, you could try one channel for 2.4ghz, and one channel for 5ghz, and see if your clients roam. Other vendor's tried this technique in the early days for Zero Hand Off (aka roaming)
JohnnyR2D2
Jul 16, 2017Guide
One last comment...
While I'm going to do the experiment with a single SSID name for all the routers I believe that having different SSIDs makes easy for anyone to identify which router it's having a problem that sometimes an easy reboot can fix. Isn't that true?
Tks,
netwrks
Jul 17, 2017Master
1,6,1 was a typo. I was trying to type 1,6,11.
While I'm going to do the experiment with a single SSID name for all the routers I believe that having different SSIDs makes easy for anyone to identify which router it's having a problem that sometimes an easy reboot can fix. Isn't that true? It will certainly help in troubleshooting problems. In a single SSID scenario, you will need to look at the AP's connected device list. you may see it on the AP's, (I'm not sure about all the different flavours of AP's you are using) or you will see it on the Base router, as to what Ethernet port it has connected to. The Ethernet port should correlate with the AP. So, if you know what AP is connected to what router port then that will also help with any troubleshooting that may be required.. Hope this helps.
