BlakeAJ83
Jan 01, 2017Aspirant
Horrible speeds on 5 ghz
Had the R7800 for about a month, haven't had any problems until a few nights ago I noticed things loading very slowly on my phone so I ran a speed test on both 5ghz & 2.4ghz from my iphone I got similar results as to what I've posted below which I ran from my PC just now. And it doesn't matter if I'm sitting 3 feet from the router I get the same results. I did a full reboot of the modem and router. I haven't tried doing a factory reset just yet. I wanted to see if anyone else had a similar problem before doing so. I'm using WPA2-PSK [AES] on both frequencies. Router Firmware Version V1.0.2.12
This is the speed I'm getting on 5ghz.
This on the 2.4ghz, this is my normal speed that I'm happy with.
This is wired speed on Windows 10 PC
Any suggestions would be appreciated.
Hi BlakeAJ83,
Reload the latest firmware and reset the router to factory default. Manually reconfigure the router and check again.
- TrikeinLuminary
Sorry, your screenshots/etc don't seem to be working.
- BlakeAJ83Aspirant
Weird I can see them and they're set to public.
Well i'll type them out:
5ghz: 3.12 mb/s download; 3.62 mb/s upload; ping 10ms
2.4ghz: 132.56 mb/s download; 10.21 mb/s upload; ping 10ms
wired ethernet: 134.68 mb/s download; 10.16 mb/s upload; ping 9ms
- TC_in_MontanaVirtuoso
I see you say that the 5GHz speeds on your phone are bad... do you have any PCs capable of hitting the 5GHz band? That way you may be able to determine whether it is the PHONE causing issues or the Router causing the issues.
Have you tried forgetting the wireless connection on your phone, then reconnecting to the 5GHz band on the phone? Sometimes on my phone I find that my connection is bad and then forgetting and reconnecting it resolves the issue.
- BlakeAJ83Aspirant
All speed test results are from a Win10 PC, which is normally wired, but I connected a wireless adapter just for testing purposes.
So to be clear, I'm getting the same results from an iPhone 7, iPad, and Windows 10 PC, testing both 2.4 & 5 ghz bands.
2.4 is running great and fast, but 5 is barely usuable, at one point i was getting 0.05 mb/s download speed.
