ferseb
Oct 08, 2021Follower
hot fix
The latest firmware release to my router is a 'hotfix' but i do not have the release before that. Should i install the release of the firmware before and then the hotix release or just go right onto the hotfix?
Thanks
You can go right to the hotfix if you want too. You don't have to apply other versions first.
1 Reply
