hbk_seanmichael's avatar
May 27, 2021
How do I disable DHCP on my AP router?
I have an R7000 as my main router connect to the ONT/Modem.  I have an ethernet cord going from the LAN of R7000 to the WAN of the R7000P. The R7000P is in AP mode. The main router (R7000) has wifi disabled.  I cant seem to find where to turn DHCP off on the R7000P. Here is images of the connection. Should I just disable the DHCP on the R7000 since i dont even have wifi active on it???  Any advice would be appreciated
  • If your R7000 is the main router, it must have DHCP enabled and working. If you set the R7000P in Access Point, DHCP is automatically disabled
