Sdg1
Dec 11, 2021Follower
how do i update my smart wifi netgear 6250 router
How do i update my smart wifi router model number 6250
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Netgear has set up a community forum specifically for General Router products. Most of the people who watch that forum are more likely to have experience with older routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you - plemansGuru - Experienced User
What model do you have?
there's an R6250 and a C6250.
the R series can be updated by the end user.
The C series, the firmware is part of the partitioning from the ISP.
So its kind of key to know what version you have to see if you can update.
