mickey7
Sep 23, 2018Aspirant
How do I use the Netgear Genie app -Step by Step
So Folks, HOW do I use the Genie app? No Clue. I have a Chromebook , so I can use the genie on it. Not compatible. I want to know how to change channel, if needed. etc. Please Help someone. I am a Newbie/Novice. Thanks.
The latest firmware for this router comes with "Added support for SHA256 certificates in lieu of MD5 for OpenVPN":
R6700 Firmware Version 1.0.1.48 | Answer | NETGEAR Support
for the V2 variant:
R6700v2 Firmware Version 1.2.0.24 | Answer | NETGEAR Support
"Supports SHA256 certificates instead of MD5 for OpenVPN".
Greetings,
Put in your model number and download the user guide for your router. You do not need Genie for windows or a mobile app. You can fully install and manage your router using nothing more than an internet browser.
- mickey7AspirantI have a Chromebook. Chromebook is NOT Compatible with the netgear router login. So...I have downloaded the android app to my Samsung tablet. I repeat, How do I use this APP?? Thanks.
mickey7 wrote:
How do I use this APP??Hard to know without any clue as to what you want to achieve.
- Turn on tablet.
- Install app
- Run app
- Connect to wifi from R6700 (see label for SSID and password)
- Login to manage
- Do whatever it is that you want to do.
There is a manual for the genie Mobile App somewhere at the end of this link:
>>>> genie Landing Page <<<<
